Bad image quality/Black screen/Distorted colors/tinted video
Follow the steps if your problem concerns bad or distorted image quality:
1. Poor image quality: camera’s lense and battery level
Before checking more detailed settings, please clean your camera’s lense and check the battery level. If needed, charge your device and compare the image quality.
2. Temperature and environment
If the videos from camera placed outside are foggy or hazy, check the camera’s environment; remove the camera skin, if you use it. Please note that the condensation and low temperature can reduce the picture quality, especially during autumn and winter.
Helpful Articles:
My outdoor Arlo camera takes foggy or hazy video at night; what do I do?
How to reduce condensation on the Arlo camera lens?
Are Arlo cameras weatherproof?
3. Inverted/upside down image
If the picture quality is good, but you see the image upside down or inverted, you can easily change that in your Arlo Secure App or through https://my.arlo.com: Settings > Device > Video Settings > Rotate Image 180°.
Helpful Articles: My Arlo camera video or image is upside down or inverted, what do I do?
4. Video settings
The video settings can be managed through the Arlo Secure App or via https://my.arlo.com. Go to Settings > Device > Video Settings and select the option “Best Video” for higher image quality. Note that this may reduce the battery life.
Helpful Articles: How do I get better picture quality from my Arlo camera?
What is the maximum video resolution of Arlo cameras?
How do I change video resolution on my Arlo Q, Arlo Q Plus, or Arlo Baby to reduce bandwidth use?
How do I adjust the video and audio settings on my Arlo device?
5. Connectivity and network requirements
The distance between your Arlo device and router may cause network interferences and consequently, poor image quality. Place your camera in a location with good WiFi signal. Perform the speed test to be sure that your network meets our product’s requirements: https://www.speedtest.net/
If your Arlo camera is connected directly to your router’s Wi-Fi network, you can also change the Wi-Fi channel for your device in the router’s settings. For more details, contact your Internet provider.
Try to reduce the number of networks, WiFi devices and transmitted frequencies near your camera and WiFi router, SmartHub, or base station.
Helpful Articles: Arlo Camera placement tips
What are the minimum requirements for installing and using my Arlo system?
6. Tinted/distorted video
If the video recorded by your Arlo device is tinted, of if the colors are distorted (for ex. the video is pink or red), try to do the following:
  • take your camera inside and wait couple of minutes (2. Temperature and environment)
  • check the battery level and charge it, if needed
  • perform a factory reset on your Arlo device.
If the problem persists, you will need our experts’ assistance.
Helpful Articles: Why are images from my Arlo camera tinted?
How do I factory reset and re-sync my Arlo Camera?
You can find all user manuals for Arlo products on our official website: https://www.arlo.com/da_dk/support
