Pro 4
Wireless Security Camera
Item No. arlo-pro-4
The Pro 4 series 2K HDR security camera delivers superior video quality combined with the convenience of connecting directly to Wi-Fi without a SmartHub. Perfect for protecting medium to larger spaces.
  • 2K video with HDR
  • Integrated Spotlight
  • Rechargeable Battery
  • Connects directly to Wi-Fi
  • Premium Two-way Audio
  • Arlo Secure trial included
Find A Retailer
See more with a 2K security camera that protects your home, even when you’re away.
Stay connected to your home from anywhere with live video and audio.
Receive instant alerts on your phone when motion is detected.
Capture clearer details and colours in 2K HDR.
Connect directly to Wi-Fi for easy wireless setup.
Works with Apple HomeKit1, Amazon Alexa, and Google Assistant.
cNet Editor's Choice Award 2021 Digital Trends 2020 Best of Year Award
Stay better informed with a closer look.
2K HDR video lets you see clearer details and colour, and zoom in on moving objects with clarity.
Never miss a thing with a wider view.
A wider 160° viewing angle ensures you have the best view of your property, no matter where you place Pro 4.
See who’s there, even at night.
Capture the full picture in low light with colour night vision, and use the integrated spotlight to illuminate your property to identify unique details.
Smart phone displaying 2K HDR video displaying moving objects during the day Smart phone displaying wider 160 degree viewing angle of property during the day Smart phone displaying person caught on camera with camera colour night vision
Arlo Pro 4 camera on ledge in living room.
fullWidthTextBubblesImagesAlts[textbubble_status] fullWidthTextBubblesImagesAlts[textbubble_status]
Respond to visitors, from anywhere.
Hear and speak to visitors clearly with 2-way audio right on your phone.
Quickly deter unwanted guests.
Trigger your siren automatically or manually from the Arlo Secure App.
Arlo camera animation with pulsing siren waves
Arlo Pro 4 camera displayed on table outside in rain with water droplets
Weather-resistant for year-round security.
Certified to withstand heat, cold, rain, or sun.
Arlo Pro 4 Wireless Security Cameras Details
Max Video Resolution
2560x1440 resolution
Image Sensor
4 megapixels
Video modes
2k, 1080p, 720p
Video Features
Auto Track and Zoom, HDR, H.264 and H.265 Encoding
Lens Field of View
160 degree diagonal
Sensor Size
1/3"
Spotlight
6500K,42Lux@1M
Single Motion Detector, 130 degree horizontal
Night Vision
High powered Infrared LEDs (850nm) with IR Cut Filter
AC Adapter Output
5V 2A
AC Adapter Input
100-240V AC, 50/60Hz
Indoor/Outdoor
Both - outdoor UV and weather-resistant
Digital Zoom
12x
Microphone
Single Microphone with noise and echo cancellation
Audio
Full Duplex 2 way Audio
Status Lights
2x LEDs (blue and amber)
Networking
802.11 b/g/n
Compliant Standards
128-bit SSL, AED-128, TSL, 2 factor authentication
Battery Life
6 months*
Charge Time to Full (via camera)
3.5 hrs
Charge time to Full (via charger accessory)
2.9 hrs
Operating Temperature
-20 to 45 degree Celsius
Connectivity
Wi-Fi Connection. Working broadband connection with at least 2Mbps upload speed
USB requirements
USB 2.0 compliant devices
Min home upload speed
2-4Mbps; optimized for 2 simultaneous 2k streams
Dimensions
316g; 89mm x 52mm x 78.4mm
Regulatory
FCC, CE, IC, EU RoHS compliant, EU-REACH compliant, EuP1275 compliant, WERCS
Wall Mount and Screw Kit
Camera with Battery
Magnetic Charging Cable
Video Monitoring Decal
quick start guide
Customers have 30 days from date of shipment to receive a refund at full purchase price. Read more on our Terms of Sale page.
View our Limited One-Year Hardware Warranty.
Frequently Asked Questions
Yes. The camera outputs 2560x1440 resolution at 16x9 aspect ratio.
No. An Arlo SmartHub or Base Station is optional. You can connect Arlo Pro 4 directly to your Wi-Fi router.
Yes. This camera can be used indoors and is weather resistant for outdoor use. The magnetic charging cable that was included with your camera is for indoor use only. To charge your camera outside, you must use the Outdoor Magnetic Charging Cable.
Yes. The Arlo Pro 4 spotlight camera turns on in low-light settings. You can also manually turn it on or off through the Arlo Secure App.
Arlo Pro 4 cameras come with an Arlo Secure trial that allows 2K streaming and cloud recording. You can also record 2K clips to local storage with the use of an Arlo SmartHub or Base Station. When your trial expires, you will need to renew the subscription to continue 2K cloud recording. For more information on Arlo subscription plans, visit: www.arlo.com/secure.
1HomeKit compatibility for Arlo Pro 4 requires connection to a compatible smarthub or base station. Visit here for Smart Hub/Base station compatibility.
2Renewal of an Arlo Secure subscription is required to maintain Arlo Secure features after the included trial. These features include cloud storage, object detection, activity zones and video history.
4To ensure optimal safety and performance, only use Arlo approved batteries, battery packs, and chargers. Unapproved batteries, battery packs or chargers present a serious risk of battery fire, explosion, battery leakage, and other product hazards. Safe Handling & Usage Guidelines
