Provide your email address to receive an email when this product is back in stock.
For the ultimate protection rain or shine, see more of what's happening with an ultra-wide field of view and 4K video with HDR. Perfect for protecting any location where you need the biggest, best view. The wired doorbell easily connects to your existing doorbell wiring. Requires existing doorbell wiring for power supply.
Arlo Essential Video Doorbell Wired (1)
Power Kit (1)
Wire Extension (1)
Flat Mounting Plate (1)
Angled Mounting Plate (1)
Wall Mount Screw Kit (1)
Security Latch Release Pin (1)
quick start guide
Video Resolution
1536x1536, 1:1
Wire Type
Hardwired Only
Max Lens Field of View
180-degree diagonal
Single Motion Sensor, 110 degree horizontal
Night Vision
Yes, high powered Infrared LED (850nm) with IR Cut Filter
Indoor/Outdoor
Outdoor UV & Weather resistant
Siren
Built-in
Digital Zoom
12x
2 Way Audio
Yes
Weight
.25lb
Dimensions
1.77 x 5.11 x 0.98in (45 x 130 x 25mm)
Arlo Ultra 2 Spotlight Camera (2)
SmartHub (1)
Power Adapter (1)
Rechargeable Batteries (2)
Ethernet Cable (1)
Magnetic Wall Mount (1)
Long Screw Mount & Screw Kit (1)
Arlo Monitoring Decal (1)
quick start guide
Video Modes
4K, 2K, 1080p, 720p
Rechargeable Battery
Max Video Resolution
4K
Night Vision
High powered Infrared LEDs (850nm) with IR Cut Filter
Lens Field of View
180
Image Sensor
Dual Motion Detectors, 150 degree horizontal
Indoor / Outdoor
Both - outdoor UV and weather-resistant
Yes
Digital Zoom
12x
Microphone
Dual Microphone Array with noise and wind cancellation
Dimensions
3.5x2x3in (89x52x78.4mm)
Arlo Pro 3 Floodlight Camera (1)
Power Adapter (1)
Micro-USB Cable (1)
Wall Plate and Screw Kit (1)
Extended XL Rechargeable Battery (1)
Arlo Window Decal (1)
quick start guide
Video Quality
2K HDR
Rechargeable Battery Life
6 months*
Max Field of View
160°
Night Vision
Color
2-Way Noise Cancelling Audio
Wind, Noise & Echo Reduction
Siren
Built-in
Indoor / Outdoor
Both
Weather Resistant
Yes
2 Way Audio
Yes, Full duplex 2 way audio
Weight
1.4lbs
Dimensions
8.6 x 7.5 x 3.07in (218.52 x 190.5 x 77.93mm)
*** Discount applied in cart. Cannot be combined with other promotions. Excludes Essential 2nd Gen cameras, Video Doorbell 2K/HD, Go 2, and security bundles. While supplies last, additional exclusions may apply.
