Provide your email address to receive an email when this product is back in stock.
Check in on security alerts to take the right action, inside and out. Cover activity inside your home and at your front door with Arlo's Home Security System with 2 All-in-One Sensors, Wireless Doorbell and Essential Indoor Camera. Bundle these security essentials & save safely today.
Arlo Essential Video Doorbell Wire-Free (1)
Battery Charging Cable (1)
Rechargeable Battery (1)
Wire Extension (1)
Flat Mounting Plate (1)
Angled Mounting Plate (1)
Wall Mount Screw Kit (1)
Security Latch Release Pin (1)
quick start guide
Video Resolution
1536x1536, 1:1
Wire Type
Wire-Free
Max Lens Field of View
180-degree diagonal
Single Motion Sensor, 110 degree horizontal
Night Vision
Yes, high powered Infrared LED (850nm) with IR Cut Filter
Indoor/Outdoor
Outdoor
Siren
Yes
Digital Zoom
12x
2 Way Audio
Yes
Weight
.25lb
Dimensions
1.77 x 5.11 x 0.98in (45 x 130 x 25mm)
*** Discount applied in cart. Cannot be combined with other promotions. Excludes Essential 2nd Gen cameras, Video Doorbell 2K/HD, Go 2, and security bundles. While supplies last, additional exclusions may apply.
1Smoke/CO alarm listening and Cellular and Battery Backup require an Arlo paid plan with Professional Monitoring for $19.99 per month after trial. Cellular and Battery Backup sold separately. Battery backup duration will vary with device settings, use, and environmental factors.
