How do I power cycle my Arlo Baby camera?
Power cycling your Arlo Baby can help to fix connection problems or screen freeze problems, and it also recalibrates Arlo Baby’s air sensors. If you are having minor technical problems with Arlo Baby, try power cycling the camera before you try more time-consuming troubleshooting steps.
To power cycle Arlo Baby:
- Unplug the USB cable from your Arlo Baby camera.
- Rotate the foot plate and remove the Arlo Baby character’s feet.
- Slide the battery switch on the bottom of Arlo Baby to off.
The battery is turned off when no green is visible near the battery switch. - Wait ten seconds, then slide the battery switch to on.
Your Arlo Baby camera restarts. - Replace the foot plate and rotate until it clicks into place.
- Plug the USB cable back in.
