What is a camera’s field of view and does it differ on Arlo wire-free cameras?
A camera’s field of view, sometimes called angle of view, is the measurement of the viewing area that the camera can capture. It is measured in degrees.
A wider field of view means that a camera has fewer blind spots and captures more area in every shot. It also means that you can mount the camera more easily, because you don’t have to do as much fine-tuning to capture exactly the right area.
The following table compares the field of view for all Arlo wire-free cameras:
