What do the LED behaviors on my Arlo Go 2 Camera mean?
The LED indicates the status of the Go 2 camera.
LED behavior during setup
LED behavior after setup
  • Solid blue: The LED lights solid blue when the camera is powered on and then turns off to conserve battery power.
    Note: the camera does not record continuously since it needs to conserve battery power.
  • Fast blinking blue: The camera’s charging cable is plugged in to a power adapter or the camera is connected to the optional Arlo Solar Panel VMA5600.
  • Single blink or double blink amber every 60 seconds: The battery charge is low. A single blink every 60 seconds indicates a low battery charge. A double blink indicates a critical battery charge level.
  • Alternating blue and amber: A firmware update is in progress.
