How do I filter events and video recordings in my Arlo Feed?
This article is for the Arlo experience with Feed. For the Arlo experience with Library, visit: How do I use the Arlo library filter?
You can use the filter to find and view events and video recordings based on criteria that you select.
Note: The Feed will depend on the Location selected in the Arlo Secure App. If you have multiple Locations set, make sure to check if you have selected the correct Location before using the filter.
To filter your Feed:
  1. Launch the Arlo Secure App.
  2. Tap Feed.
  3. Tap
  4. Tap Event Type or Devices.
  5. Tap the switches to select or deselect the FILTER TYPES.
  6. Tap < to go back to the previous screen.
  7. Tap Save.
    Your Arlo Feed is now filtered according to your selected criteria.
When you use filters, only the events and video recordings in your Feed that match your selected filter types are displayed.
To turn off filters in your Feed:
  2. Tap Feed.
  3. Tap
  4. Tap Event Type.
  5. Tap Select All.
  7. Tap Devices.
  8. Tap Select All.
  9. Tap < to go back to the previous screen.
  10. Tap Save.
    Your Arlo Feed will now show all Event Types for all Devices.
