How do I adjust Arlo video recording length? - Arlo Secure 4.0
Most Arlo cameras can record until activity stops, up to 5 minutes. If you set the camera to record until activity stops, the camera will record as long as it detects audio or motion (up to 5 minutes). If the event exceeds 5 minutes, a new recording will start. You can also set your Arlo cameras to record videos for a fixed length from 10 seconds to 2 minutes long. Recording requires either an Arlo Secure subscription or local storage.
For more information, visit:
To adjust Arlo video recording length:
  1. Launch the Arlo Secure App.
  2. Tap Devices.
  3. Select the device you want to adjust.
  4. Tap
  5. Tap Default Mode Settings.
  6. Under RECORDING LENGTH, select between Record until activity stops for recording length up to 5 minutes, or Record for a fixed length. Move the slider to adjust the recording length from 10 seconds to 2 minutes.
