How do I change the Location of my Arlo device on Arlo Secure 4.0?
You can change your Arlo device Location in the Arlo Secure App or on my.arlo.com. You need to have at least two Locations configured in your Arlo account to be able to change Locations. If you are moving a device to a new Location, create the Location first before moving devices. For more information, visit: How do I create, delete, or edit a Location in the Arlo Secure App?
To change the Location of your Arlo device on a web browser:
  1. Log in to your account at my.arlo.com.
  2. Click Settings.
  3. Under Locations and Plans, select the Location name where the device is currently located.
  4. Click Devices.
  5. Select the device you want to change.
  6. Click the camera name at the top of the screen.
  7. Click Change Device Location.
    Note: The Change Device Location option will only appear if you have two or more Locations.
  8. Select the desired Location to move your device to.
    Note: Make sure you have an active subscription in your Location. Moving devices may affect Modes and Rules.
  9. Click Done.
To change the Location of your Arlo device on a mobile device:
  1. Launch the Arlo Secure App.
  2. Tap
  4. Tap Devices.
  6. Tap the camera name at the top of the Device Settings screen.
  7. Tap the current Location name.
  8. Select the new Location where you want to move the device to.
    Note: Location options will only appear if you have two or more Locations. Make sure you have an active subscription in your Location. Moving devices may affect Modes and Rules.
