How far can I place my Arlo cameras from my Arlo SmartHub or Base Station?
Keep maximum and minimum distances in mind when placing your Arlo cameras:
Maximum. You can place your Arlo camera a maximum of 300 feet (90 meters) from the Arlo SmartHub or Base Station. The maximum line-of-sight range of 300 feet is reduced by each wall, ceiling, or other major obstruction between the camera and Arlo SmartHub or Base Station. The following materials reduce signal strength the most:
  • Large quantities of water, such as the water in a fish tank or water heater
  • Metal
  • Glass, especially mirrors
  • Ceramic
  • Stone
  • Concrete
  • Brick
  • Unusually thick walls and ceilings
Minimum. Place your Arlo cameras at least 10 feet (3 meters) from the Arlo SmartHub or Base Station, and allow at least 6.5 feet (2 meters) between cameras. Follow these guidelines to prevent Wi-Fi signals between the devices from interfering with each other.
