Arlo Go 2 Camera Product Tour
This article applies to
Arlo Secure offers intelligent services for greater control over how you view, manage, connect, and respond to events that occur around your home or business. Create custom activity zones to focus on important areas and receive alerts when something happens. Arlo can tell the difference between a person, animal, vehicle, or a package. You can view your Arlo Secure Plus recordings for up to 60 days.
Note: This article applies to European regions and the UK. For more information, visit Arlo Secure Plans.
The benefits of Arlo Secure
Enhance your security experience with Arlo Secure, and you’ll receive more intelligent motion alerts so that you can take quick action, such as call a friend or sound an alarm. To access these options, tap and hold an Arlo interactive notification on your mobile device.
- Microphone: Use the microphone and speaker for a full-duplex two-way conversation.
- Spotlight: Activate the integrated spotlight manually, or set it to trigger when motion or sound is detected. For more information, visit How does the spotlight on my Arlo camera work?
- Camera Lens: Keep an eye on more of what matters with a wide 130-degree field of view.
- Status LED: Determine the status of your Arlo Go 2 Camera by referring to the LED indicator. For more information, visit What do the LED behaviors on my Arlo Go 2 Camera mean?
- Light Sensor: The light sensor is used to determine when to trigger the integrated spotlight. For more information, visit How does the spotlight on my Arlo camera work?
- Speaker: Use 2-Way Audio to have a conversation, or deter intruders by activating the siren. For more information, visit How do I turn on or off the siren on my Arlo camera or doorbell?
- Sync Button: After releasing the camera from the camera housing, manually start the syncing process or factory reset your Arlo camera by pressing this button. For more information, visit What is the sync button on my Arlo Go 2 Camera?
- Weather Resistant Camera Housing: Use your Arlo Go 2 Camera indoors or outdoors. For more information, visit Are Arlo cameras weatherproof?
- Charging Port: Charge your camera battery with the magnetic charging cable that came with your camera.
- Release Button: Press this button to release your Go 2 camera from the camera housing. This lets you access the battery and the SIM card, the sync button, and the SD card slot. For more information, visit How do I insert the battery in my Arlo Go 2 camera?
- SIM Card Slot: An activated SIM card is required for mobile broadband access. For more information, visit How do I install a SIM card in my Arlo Go 2 camera?.
- SD Card Slot: You can use an optional micro SD card (sold separately) for local storage. For more information, visit How do I install an SD card in my Arlo Go 2 camera?.
- Screw Mount Hole: Use the screw mount hole to attach your camera to the camera mount. For more information, visit How do I mount my Arlo Go 2 Camera?
