How do I set up my Arlo Go 2 Camera?
The Arlo Go 2 camera works with the same Arlo app as all other Arlo cameras and devices. However, to connect your Go 2 camera to the mobile network, an activated SIM card with a mobile data plan must be inserted into the Go 2 camera.
Note: We recommend that you charge the battery before mounting your camera. The indoor charging cable that came with your camera works with most power adapters.
To set up your Arlo Go 2 camera:
- Launch the Arlo app or log in to my.arlo.com.
- Tap or click Add Device.
- Follow the prompts to add your Arlo Go 2 camera.
During the setup process, the Arlo app:
- Detects the activated SIM card in your camera and attempts to access the mobile network associated with the SIM card.
- Prompts you to scan one or more QR codes displayed in the app with your Go 2 Camera.
- Discovers your camera and offers you the option to connect to a 2.4 GHz WiFi network. Only use this option when the camera is in range of a WiFi network.
- Guides you through camera positioning and mounting.
